Door Locking Problem
I'm having a problem with both my doors locking on my 93 SC400 so i have to manually lock both doors from inside. You can hear nothing when you try to lock both doors when using the switch but you can hear them unlock when you move the switch to the unlock position. Now currently my drivers side window needs a window regulator do you think this has to do with the motor or the switch being bad on both doors please help!!!!! Will appreciate all responses
  • 4 months later...
I had issues with locking unlocking using the switch. And for many days I had to manually do it.
It all fixed itself after I changed the battery. You can try charging the battery from a local store and give that a shot... just a suggestion.
