Strut Bar
bbsal
I got the same strut bar. When i had it on, the engine seem to be restricted because the strut bar was in the way. Every time i reversed, there would be a big clank because the engine manifold hits the bar. It wears away the lining under the hood too. Since then i took the bar off. If you put it on, tell me how well it works.
that is how they made those types of round bars
mine is not like that and fits prefectly
with yours
all you have to do is buy a few washers
place one at a time and try it to get the clearance needed
mainly on the inner most nut only
then it should clear fine
  • 3 months later...
BBSAL,
So you bought from Autobacs1 and the bar does not clang when going into reverse, or wear on the hood lining?
I am a new (used lexus) owner and am still in that "double check everything" mode.
Thanks for the info,
Darrell
