bccdbc Posted February 25, 2006 Share Posted February 25, 2006 Noticed the TRACTION light came on while drivng at Hiway speed. stared car next morning no light, drove a mile or so light came on. Pattern seem to repeat it self. Noticed that light comes on when a 'bump' in the road is encountered. Pullled fuse for 4 days(traction light on entire time), reinserted, same problem. Any/All ideas appreciated Quote Link to comment Share on other sites More sharing options...
mobbrobb Posted February 27, 2006 Share Posted February 27, 2006 TRAC light is constantly lit on my 92 SC400; if there is any easy fix, please post. Quote Link to comment Share on other sites More sharing options...
SC400DBS Posted March 13, 2006 Share Posted March 13, 2006 I have exact same problem, same car. I have noticed that the traction control does not work, so in my case at least the light is providing a real indication of a problem. When first starting out, I can hear a light, repetitive grinding noise coming from under the hood which I believe to be the TRAC system trying to start up - after about 10 cycles, the noise stops then the TRAC light comes on. The car runs fine and on dry pavement, I notice no issues. However, I get very poor traction accelleration out of turns on wet pavement. Suggested fixes, short of going to the dealer? Thanks Quote Link to comment Share on other sites More sharing options...
Soaring Posted March 13, 2006 Share Posted March 13, 2006 Sometimes when your rear brake pads are low or your rotors are too thin, it'll set off the sensor. I had my traction light coming on and then I replaced the rear pads and rotors (which are super cheap by the way) and the light went off never to return. Quote Link to comment Share on other sites More sharing options...
Paul_Cos Posted April 30, 2006 Share Posted April 30, 2006 TRAC light is constantly lit on my 92 SC400; if there is any easy fix, please post. I have the same problem with my 95 SC300. Have tried many fixes over the last 3 years....nothing seems to work for very long. If I immediately spin the wheels (engage the trac system) shortly after startup....before it shuts down, sometimes it will remail "fixed" for a few days. Quote Link to comment Share on other sites More sharing options...
