Rear Hatch Rattle Tsb?
Booyah
With all the problems with the rear hatch rattling and making odd sounds is there a TSB that anybody knows of for this? What is it.
If not do you have a detailed description of what the dealer did to fix it
my rattle which was quite loud that developed after 5K miles was in the rear inside quarter panel on the left side. the dealer fixed it in about half an hours time by adding additional material behind that area. it looks like the rattles have different causes and locations, so im not sure a tsb would work in all cases.
the rattle in the rear hatch is caused by the two side tabs which are located on the inside of the car - not on the hatch itself being in the "up" position where they will click,or contact the hatch when it is closed. you need to push the tabs back and down in the "locked" position so they will not contact the hatch when it is closed. contact me directly if you have questions. tharnett@earthlink.net
