Retrofit Ls400
ko90ls
"Good Things Come To Those Who Wait."
here are the updated pics and a short story. I cut the bracket using the dremel and the reinforced cutting discs since the regular ones broke. i also used the drill bit on the dremel to cut the mounting holes. The Rubber dust boot is off a J30(infiniti) headlight and fits perfectly on the headlight housing. this is just for practice and the final product will be a little different. I also will prob sand the whole headlight glass for better light output.
PS sorry for the dark pics
  • 2 months later...
I was looking on g20.net and found some retrofit info. Someone made a custom Angel eye for their car and here is the directions: http://www.diyautomods.com/forum/showthread.php?t=8
I have a LS400 and I installed 6000K HID with Hi/Low (Telescopic) Kit. It looks great but I cannot get the light pattern you get on projectors. I wonder if there is a way to cut the front and make it clear with either another headlight that might match it or some plexiglass that can be molded and glued so I can put a set of projectors inside the housing. Have anyone tried or heard about this aproach? Great topic!
