Hello,
I have a 2004 ES330.
I would like to know if my '04 ES330 can be programed to turn the rear view mirrors downward when I put my car in reverse, like the 2005 ES330 does.
Hello,
Not without extensive wiring changes. A Lexus dealer would not even attempt this type of modification.
A long way around would be to use the #2 seat position memory switch.
Of course this is would require shifting to park and while still stepping on the brake, press the number #2 switch. The number 2 settings would be the same as the #1 settings with the exception that the mirros were in the down position when the memory was set. The mirrors will move to the desired position, then shift to reverse.
Kind of a long way around but do able. Definately not like the real thing, though.
steviej
