lexus400 Posted January 17, 2006 Posted January 17, 2006 '96 ES. I replaced the EGR valve but am still getting the same code. What should I try next ? any ideas ? Bob
LexInfo Posted January 17, 2006 Posted January 17, 2006 '96 ES. I replaced the EGR valve but am still getting the same code. What should I try next ? any ideas ? Bob theres a EGR position sensor on top of the EGR valve, make sure thats working properly with a volt meter and find the EGR VSV located on the VSV rail on top of the engine by the intake manifold and check the VSV operation, make sure theres vacuum going to the EGR modulator and out to the valve... i've seen a couple of the EGR position sensor malfunction that caused the same problem. Good luck
Toysrme Posted January 17, 2006 Posted January 17, 2006 Pull the EGR position sensor connector off & shove a 10ohm resistor in it. If you fail emessions testing, something is still broken.
mehullica Posted January 18, 2006 Posted January 18, 2006 1996 es300 doesn't have an EGR position sensor. Check hoe much vacuum you have at the EGR valve, engine hot @ 2500 rpms. More than likely the modulator is bad
chuckb Posted January 19, 2006 Posted January 19, 2006 1996 es300 doesn't have an EGR position sensor. Check hoe much vacuum you have at the EGR valve, engine hot @ 2500 rpms. More than likely the modulator is bad modulator is what I meant to say. my 95 es has the same cel right now. I'm scared to buy a new egr and then it may be the modulator, as mentioned. I don't have a vacum tester, any other way to check it.
timber Posted January 21, 2006 Posted January 21, 2006 1996 es300 doesn't have an EGR position sensor. Check hoe much vacuum you have at the EGR valve, engine hot @ 2500 rpms. More than likely the modulator is bad modulator is what I meant to say. my 95 es has the same cel right now. I'm scared to buy a new egr and then it may be the modulator, as mentioned. I don't have a vacum tester, any other way to check it. I have a 94 es300 that had a P0401 code and I just replaced the vacuum modulator. I purchased a new one, and before I installed it I compared it to the old one. What i noticed was the diaphragm on the old one was completely dried out. It would not hold a vacuum when applied to the bottom hole. The new one did. If you don't have a vacuum tester just hook a vacuum line to it and use your built in vacuum pump :-). Just because I am a curious sort I took apart the old one, and it was completely dried up and has some sort of liquid inside it ?? I assume it is condensation, but who knows ?? I was kind of easter egging to figure out what was wrong, but I did get some good info from this site...
saltyreefguy Posted August 13, 2006 Posted August 13, 2006 1996 es300 doesn't have an EGR position sensor. Check hoe much vacuum you have at the EGR valve, engine hot @ 2500 rpms. More than likely the modulator is bad modulator is what I meant to say. my 95 es has the same cel right now. I'm scared to buy a new egr and then it may be the modulator, as mentioned. I don't have a vacum tester, any other way to check it. I have a 94 es300 that had a P0401 code and I just replaced the vacuum modulator. I purchased a new one, and before I installed it I compared it to the old one. What i noticed was the diaphragm on the old one was completely dried out. It would not hold a vacuum when applied to the bottom hole. The new one did. If you don't have a vacuum tester just hook a vacuum line to it and use your built in vacuum pump :-). Just because I am a curious sort I took apart the old one, and it was completely dried up and has some sort of liquid inside it ?? I assume it is condensation, but who knows ?? I was kind of easter egging to figure out what was wrong, but I did get some good info from this site... could i ask you where is the modulator located on a 96 es300? also there was a link to download a manual for a camry, but since then my pc crashed and lost all the pdf files on the vechile, since the camry is similiar to the lexus. thanks, if you could help. sorry would have sent you a pm, instead of bringing up this old thread, but the site will not allow me yet.
anthonyiez Posted August 16, 2006 Posted August 16, 2006 low flow egr problems... replace valve transducer egr switching valve also make sure to clean out all the passages going to and from the egr valve very good.
chuckb Posted August 16, 2006 Posted August 16, 2006 my problem was the egr modulator. it was easy to change and light's gone.
Best Pal Posted August 20, 2007 Posted August 20, 2007 Here is the repair manual for '92-'96 Toyota Camry and Lexus ES300 in PDF format: http://www.turboninjas.com/camry/ It helped me a lot to do the testing of the EGR system. Pictures DO help! Just follow the procedures chart (you can skip the computer test). Basically, clean the pipes, do vacuum test of you EGR Valve itself and then if it's OK vacuum test the EGR modulator. Most likely you will fond you problem by those simple tests.
