skenn1977 Posted December 6, 2005 Posted December 6, 2005 Any one have thoughts on the effort to change the alternator on a GS400? I've changed them before but not sure how easy or hard it is to get at the GS400's? Is this a 1, 2, 4 hour job?
lenore Posted December 6, 2005 Posted December 6, 2005 Sorry nobody is responding, I do not have a GS but generally alternators are not bad to replace. Usually two bolts hold them on. Disconnect the negative lead on the battery to start the process, then remove the drive belt, unhook the plug and wires to the alternator and remove the two bolts that secure it. Installation is the reverse finishing with the battery negative terminal.
Lextreme Posted December 10, 2005 Posted December 10, 2005 Here is what i have to this tutorial. Its for LS and SC but it would be the same as the GS How to Replace Lexus Alternator
lenore Posted December 10, 2005 Posted December 10, 2005 Here is what i have to this tutorial. Its for LS and SC but it would be the same as the GS How to Replace Lexus Alternator ← Hey I was right, but your tuturol is absolutely great. Great addition.
driver6 Posted March 4, 2017 Posted March 4, 2017 cant it be removed by the bottom? isnt it much simpler?
