Hi All,
It's been foggy for about a week now in the Everett, WA area and this is when I notice my headlights are pointing upward and to the right. The passenger side headlight is just pointing a bit upward. The driver side headlight is pointing too much to the right and upward. Does anybody have any instruction on how to adjust the headlights?
Thanks,
MoonySC400
If you look in the engine bay, you should see the bubble level used to adjust the vertical of the head lights. Adjust the bubble to the middle should correct this. Then there is another adjustment for the horizontal. It should be pretty obvious if you take a look.
Good Luck!
