I need the pin diagram for the 2JZ-GE engine.
I have a 2001 GS300 and I'm going to be installing a S-AFC-II air/fuel chip from Apexi.
The book from Apexi had a map for a 2JZ-GE year 93-97 and a 2JZ-GTE year 98-02 only.
So, if anyone has the pin diagram for a 2JZ-GE engine, year 2001, please post here or email me.
Doing the install in a few days so I need it quick.
Thanks!!
  • 3 years later...
Hi
Have u managed to get the pin Diagram, my Lexus GS300 (yr 2001)
is having strartup problem, Cranking is ok, engine start a moment then goes off (death).
I have been trying to reset ECU checking all fuses, everything seems ok,
Now next step is to check ECU condition, need the pin diagram to check whether ECU is giving right output.
Thank you
Hi
Thank you
im sure sometime in the last 3 years he found a pin diagram.....since this topic started in 2005
let me see if i can find u one....
nope sorry....i used to have one of it even though i dont have a gs300. ask guytelefunken or dcfish
Hope this helps you heres a website. BTW I need a detailed diagram for my gs300 im boosting im installing the greddy emanage do you know anything. http://www.projectgs.com/DIY/Engine/ECU_Pi...GS300_98-00.gif
ok we BOTH apparantally stealing off jeff's DIY BUTTTTTTTTTTT the wiring diagram u gave him is incorrect
this is the one he needs....its on the top
http://www.projectgs.com/DIY/Engine/ECU_Pinout/index.htm
he has a 2001 gs300 and you posted the pinout for a 98-2000 gs300
