Windshield Washer Pump For Sc400
Mr.SC
Hey whats going on....just wanted to know if anyone knows where i can get the pump for the windshield washer. Mine doesnt work anymore when i press the button for the fluid....also how do i get to it and remove it...maybe its clogged or there is a lose connection...thanks for the help...
Are you sure that it is the pump, and not a clog in the lines/nozzles?
An easy way to test this, would be to open your hood. Underneath the insulation, you'll find the washer fluid lines. At a point or two, you'll find a connection point. Or you can disconnect the lines from the nozzle base. Disconnect the line and (you might want to have a friend somewhat cap the line to create some pressure) press the washer fluid.
If not this, then it could be the pump...unless there is a fuse that I don't yet know about...
  • 3 weeks later...
  • 1 month later...
