I may need a new starter :cries: on my '93 SC300. Getting a clicking noise occasionally on startup. Going to check all connections today. If thats not the problem then I probably will need a starter. I checked out this sight http://catalog.eautopartscatalog.com/ipb/w...=F∂=Starter and found 2 types of rebuilt staters
1. Bosch for $104 with $75 core charge
2. Denso for $140 with $40 core charge
Has anyone used either of these?
Does anyone know the part numbers for the rebuild kit? Thnx
Many times...
The most common failure of starter motors is the commutator brushes and so the most common overhaul is a cleanup and brush replacement.
