Hokie Posted July 14, 2003 Posted July 14, 2003 I am getting terrible reception on local stations that I should be getting in clear. They are clear in all other vehicles I have. Someone mentioned that in might be a grounding problem. Can you help me out . Thanks,
SKperformance Posted July 14, 2003 Posted July 14, 2003 is it just static or a hum? is the ant going up at the rear of the vehicle? i am not sure it it even has an ant or if it is built into the rear window
Hokie Posted July 15, 2003 Author Posted July 15, 2003 No static. the stations just don't come in very well and are real quiet compared to some others. It's like they are not local stations when they are.
avrobot Posted July 15, 2003 Posted July 15, 2003 It sounds as if you might have a bad connection from your radio to your antenna. It could be the cable or the connectors.
