can anyone tell me how i get the plastic housing off the third brake light to change a bulb? the owners manual says to contact the dealer but i bought the bulb and want to do it myself. thanks.
It comes out from above.... you can DIY!!!
I tried to get it off from underneath at first -- but that's a no go!
Seemed like there where a couple screws and then you pull straight out - it seats pretty tight up on the back glass so be patient..
The whole casing slides away - then you can access the bulb(s). I think just one side went out on mine......
ok thanks. i looked at it quickly over the weekend and didn't see any screws but i'll look again. your right it
s only one side that's out.
Hey -
I had to go look real quick...........there are no screws.....
But I know I slide it out from the top. IT's kinda tight; you'll have to press this way and that way - but that's how it comes off.
Good luck!!!
Take a flat blade screwdriver with tape over the end so you don't damage anything and slide the edge under the cover nearest the seatback and lift firmly/pop up.
Ya'll rock!
My center brake light burned out Friday evening. I searched this site and googled the net for procedures, no luck. Removed panels from the trunk to gain access from below, no luck. I resigned myself to a Sewell Lexus visit, I love to visit but the drive is 35 miles one-way....Then today, ya'll post the procedures. It works for the 430 as well.
Took 2 minutes, wife thinks I am a wizard!
Thanks for making me look good, and saving me the trip!
:cheers:
Ya'll rock!
