Maximaboy1 Posted September 4, 2005 Share Posted September 4, 2005 Hi, When I'm driving the SC along paved roads, the car sometimes tends to follow the cracks at slow speeds (<40) and such in the road (steering wheel steers itself from left to right slightly). What could be the cause? Quote Link to comment Share on other sites More sharing options...
bartkat Posted September 4, 2005 Share Posted September 4, 2005 It's most likely the tire design, or they are getting worn down. It's called nibbling and some tires are worse than others. The early high performance tires were really bad about that. Quote Link to comment Share on other sites More sharing options...
lexus082 Posted September 5, 2005 Share Posted September 5, 2005 Hi,When I'm driving the SC along paved roads, the car sometimes tends to follow the cracks at slow speeds (<40) and such in the road (steering wheel steers itself from left to right slightly). What could be the cause? ← Check Control arm bushings and ball joints. That usually is the cause. You may also want to look into replacing the steering bushings if you have somewhat high mileage. A good way to make sure the ball joint on each wheel is ok is to jack the wheel up and then tug the bottom of the tire or the top towards you to check to see if there's any movement. Quote Link to comment Share on other sites More sharing options...
vigillinus Posted September 5, 2005 Share Posted September 5, 2005 Hi,When I'm driving the SC along paved roads, the car sometimes tends to follow the cracks at slow speeds (<40) and such in the road (steering wheel steers itself from left to right slightly). What could be the cause? ← I changed to Michelin Pilot Sport tires on my 2002 SC430 and got rid of most of what you are complaining about. The original tires stunk. Check Control arm bushings and ball joints. That usually is the cause. You may also want to look into replacing the steering bushings if you have somewhat high mileage. A good way to make sure the ball joint on each wheel is ok is to jack the wheel up and then tug the bottom of the tire or the top towards you to check to see if there's any movement. ← Quote Link to comment Share on other sites More sharing options...
Maximaboy1 Posted September 5, 2005 Author Share Posted September 5, 2005 I doubt it's the tires. I've had the car since 80K miles and it's now at 108K. It has ahppened since day 1, which had Bridgestone RE730 tires and now it has worn BfGoodrich KDWS tires. I'm guessing it's the bushings or something. How much would it cost to replace those things? thanks for the responses..I love this forum. Quote Link to comment Share on other sites More sharing options...
don_juan_miami Posted September 6, 2005 Share Posted September 6, 2005 hey bro, yea i had the same problem one time. I had gone on a drunken rampage one night in the grove and hit a sidewalk dirty style. After that the car would take any small deviation in the asphalt and... well for lack of a better term... follow it. The yaw of the tires was off. ( i think it yaw, i know its not camber.) Anyway, my right front tire was like 4 degrees off center, which... one, caused the car to handle horribly, and two tweaked my steering wheel quite a bit. I bet it would worn the hell out of the tires, alas the day would not come. A couple days later, some cuban lady sideswiped me and poof, it was gone. Anyway, i was just saying that i think it might be an allignment problem. Good luck man. happy Hunting Juancho Quote Link to comment Share on other sites More sharing options...
Theodore Posted September 7, 2005 Share Posted September 7, 2005 i changed the bushings and iot stopped, control arms bushings and stabalizer. But i did also get new tires same time. Sooooooooooooo. Get the Daizen Bushings for the control arms there only 185 bucks for the front, ur car defintly needs them anyways with 108k on it. Quote Link to comment Share on other sites More sharing options...
Maximaboy1 Posted September 8, 2005 Author Share Posted September 8, 2005 So Control Arm Bushings alone should do it? Quote Link to comment Share on other sites More sharing options...
jzz30 Posted September 8, 2005 Share Posted September 8, 2005 could be a combination of things Quote Link to comment Share on other sites More sharing options...
MitchB Posted September 11, 2005 Share Posted September 11, 2005 When's the last time you had an alignment? Front toe could be set too far out, whch makes the car dart-y and it will tramline a lot more than it should. Quote Link to comment Share on other sites More sharing options...
Maximaboy1 Posted September 11, 2005 Author Share Posted September 11, 2005 Probably 50K miles ago...Umm, the car goes straight when I let go of the wheel.... Quote Link to comment Share on other sites More sharing options...
UCF3 Posted September 11, 2005 Share Posted September 11, 2005 What PSi is your tire pressure at? Quote Link to comment Share on other sites More sharing options...
MitchB Posted September 11, 2005 Share Posted September 11, 2005 Probably 50K miles ago...Umm, the car goes straight when I let go of the wheel.... ← That's a function of caster. Toe-in (or toe-out) affects how quickly the car responds to changes of the wheel. For instance, most autocrossers like to toe out their cars for better response. Sure, just don't drive it on the highway. :) Quote Link to comment Share on other sites More sharing options...
don_juan_miami Posted September 12, 2005 Share Posted September 12, 2005 TOE! Thats the word i was looking for!!! What did i say? yaw? Wow im a spaz..... :) Juancho Quote Link to comment Share on other sites More sharing options...
arnie1 Posted September 16, 2005 Share Posted September 16, 2005 The run flat tires are like that because of the very hard sidewalls. When they wear out, get conventional tires. Quote Link to comment Share on other sites More sharing options...
