Droe Posted August 25, 2005 Posted August 25, 2005 I just got a 1993 LS400 a couple weeks ago. The keyless remote was working fine. I had the car detailed and the remote has not worked since, even after replacing the battery. Is there a fuse for the system and if there is where would it be located? Thank you.
Rusty Posted August 25, 2005 Posted August 25, 2005 There is an On/Off switch for the remote on the left side of your lower dashboard, near the trunk and engine compartment releases. Maybe when the car was detailed they hit the switch.
sha4000 Posted August 25, 2005 Posted August 25, 2005 is i working and you just cant hear it?then they just probably hit the knob
