93 Ls400 Keyless Remote Fuse?
Droe
:huh: I just got a 1993 LS400 a couple weeks ago. The keyless remote was working fine. I had the car detailed and the remote has not worked since, even after replacing the battery. Is there a fuse for the system and if there is where would it be located? Thank you.
There is an On/Off switch for the remote on the left side of your lower dashboard, near the trunk and engine compartment releases.
Maybe when the car was detailed they hit the switch.
