JDOwen2 Posted August 22, 2005 Share Posted August 22, 2005 I replaced my passenger side door actuator. Originally the small white plastic clip that hods the actuator rod to the door handle broke. I tried unsuccesfully to make something work because I couldn't find the clip. After removing the door panel I removed the cross beam to gain access to the actuator. I had to take out the door handle for a little more access and unbolted the actuator. I removed the four screws holding the rear window track and was able to pull the actuator out with a little fumbling around. I installed the new actuator but had to install the plastic clips onto the door handle with the door handle removed from the body. Took me an hour and a half. Getting the lock set to line up was the hardest part. Toyota sells the clip, Lexus doesn't. Quote Link to comment Share on other sites More sharing options...
VincyRay Posted August 29, 2005 Share Posted August 29, 2005 Where did you find the actuator? When I called the dealer, they told me I'd have to buy a new handle to get a clip and a new latch for the rod. Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted August 30, 2005 Author Share Posted August 30, 2005 I got the actuator off Ebay. I posted the part numbers for the clips awhile ago. You could also try a salvage yard. Quote Link to comment Share on other sites More sharing options...
pablo170 Posted December 9, 2008 Share Posted December 9, 2008 I have the same 95 SC300 and need the clip for the passenger door rod. Do you still have the Toyota part number? Many Thanks Paul Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted December 9, 2008 Share Posted December 9, 2008 pablo170, This link has the part/#. http://northlandfasteners.biz/Store/index.php?cPath=279_349 Quote Link to comment Share on other sites More sharing options...
