Rusty Posted August 12, 2005 Posted August 12, 2005 The Pioner Premium Sound system in my 1993 LS400 has low volume and no bass. I would like to bring it to a repair shop where it can be examined to determine if the problem is in the head unit, amps or speakers. Can someone recommend a shop in the Boston/Southern New Hampshire area that has experience with the Lexus/Pioneer systems ? Thank you
easylabor Posted August 15, 2005 Posted August 15, 2005 I called a local lexus-authorized repair shop that I found in the phonebook and they referred me to an electronics shop that repaired OEM stereos. The Pioner Premium Sound system in my 1993 LS400 has low volume and no bass.I would like to bring it to a repair shop where it can be examined to determine if the problem is in the head unit, amps or speakers. Can someone recommend a shop in the Boston/Southern New Hampshire area that has experience with the Lexus/Pioneer systems ? Thank you ←
jmw Posted January 7, 2008 Posted January 7, 2008 I called a local lexus-authorized repair shop that I found in the phonebook and they referred me to an electronics shop that repaired OEM stereos.The Pioner Premium Sound system in my 1993 LS400 has low volume and no bass.I would like to bring it to a repair shop where it can be examined to determine if the problem is in the head unit, amps or speakers. Can someone recommend a shop in the Boston/Southern New Hampshire area that has experience with the Lexus/Pioneer systems ? Thank you <{POST_SNAPBACK}>
jmw Posted January 7, 2008 Posted January 7, 2008 I called a local lexus-authorized repair shop that I found in the phonebook and they referred me to an electronics shop that repaired OEM stereos.The Pioner Premium Sound system in my 1993 LS400 has low volume and no bass.I would like to bring it to a repair shop where it can be examined to determine if the problem is in the head unit, amps or speakers. Can someone recommend a shop in the Boston/Southern New Hampshire area that has experience with the Lexus/Pioneer systems ? Thank you <{POST_SNAPBACK}> I had the same problem with my 93 and sent the unit to Southern Electronics in Richmond, Va. based on a recommendation and they did an excellent job. About 3 days turnaround. Joe
