Obd Ii Code P1135
Mbasie
Does anyone know what this really means?
"P1135  - Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)"
what part needs to be purchased? Can this be ignored?
P0100
MAF Malfunction
P0101
MAF Circuit Range/Performance
P0110
IAT Circuit Malfunction
P0115
ECT Circuit Malfunction
P0116
ECT Circuit Range/Performance
P0120
TP Position Sensor/Switch ‘‘A’’ Circuit Malfunction
P0121
TP Position Sensor/Switch ‘‘A’’ Circuit Range/Performance
P0125
Insufficient Coolant Temperature For Closed Loop Fuel Control
P0130
HO2S Circuit Malfunction, Bank 1 Sensor 1
P0133
HO2S Circuit Slow Response, Bank 1 Sensor 1
P0135
HO2S Heater Circuit Malfunction, Bank 1 Sensor 1
P0136
HO2S Circuit Malfunction, Bank 1 Sensor 2
P0141
HO2S Heater Circuit Malfunction, Bank 1 Sensor 2
P0150
HO2S Circuit Malfunction, Bank 2 Sensor 1
P0153
HO2S Circuit Slow Response, Bank 2 Sensor 1
P0155
HO2S Heater Circuit Malfunction, Bank 2 Sensor 1
P0156
HO2S Sensor Circuit Malfunction, Bank 2 Sensor 2
P0161
HO2S Heater Circuit Malfunction, Bank 2 Sensor 2
P0170
Fuel Trim Malfunction
P0171
System Too Lean (Fuel Trim)
P0172
System Too Rich (Fuel Trim)
P0174
System Too Lean (A/F Lean Malfunction, Bank 2)
P0175
System Too Rich (A/F Rich Malfunction, Bank 2)
P0300
Random Misfire Detected
P0301
Misfire Detected, Cylinder 1
P0302
Misfire Detected, Cylinder 2
P0303
Misfire Detected, Cylinder 3
P0304
Misfire Detected, Cylinder 4
P0305
Misfire Detected, Cylinder 5
P0306
Misfire Detected, Cylinder 6
P0307
Misfire Detected, Cylinder 7
P0308
Misfire Detected, Cylinder 8
P0325
KS 1 Circuit Malfunction
P0330
KS 2 Circuit Malfunction
P0335
CKP Sensor ‘‘A’’ Circuit Malfunction
P0340
CMP Circuit Malfunction
P0385
CKP Sensor ‘‘B’’ Circuit Malfunction
P0401
EGR Insufficient Flow
P0402
EGR Excessive Flow
P0403
EGR Circuit Malfunction
P0420
Catalyst System Efficiency Below Threshold Bank 1
P0430
Catalyst System Efficiency Below Threshold Bank 2
P0440
EVAP Emission Control System Malfunction
P0441
EVAP Emission Control System Improper Purge Flow
P0446
EVAP Emission Control System Vent Control Malfunction
P0450
EVAP Emission Control System Pressure Switch Malfunction
P0451
EVAP Control System Pressure Sensor Range/Performance
P0500
VSS Malfunction
P0505
Idle Control System Malfunction
P0510
Closed TP Switch Malfunction
P0550
Power Steering Pressure Sensor Circuit Malfunction
P1100
BARO Sensor Circuit Malfunction
P1120
Accelerator Pedal Position Sensor Circuit Malfunction
P1121
Accelerator Pedal Position Sensor Range/Performance Problem
P1125
Throttle Control Motor Circuit Malfunction
P1126
Magnetic Clutch Circuit Malfunction
P1127
ECTS Actuator Power Source Circuit Malfunction
P1128
Throttle Control Motor Lock Malfunction
P1129
Electronic Throttle Control System
P1130
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 1 Sensor 1)
P1133
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 1 Sensor 1)
P1135
P1150
Air/Fuel Ratio Sensor Circuit Range/Performance Malfunction (Bank 2 Sensor 1)
P1153
Air/Fuel Ratio Sensor Circuit Response Malfunction (Bank 2 Sensor 1)
P1155
P1200
Fuel Pump Relay/ECU Circuit Malfunction
P1300
Igniter Circuit Malfunction (Bank 1 Or No. 1)
P1305
Igniter Circuit Malfunction, (Bank 2 Or No. 2)
P1310
Igniter Circuit Malfunction (No. 3)
P1315
Igniter Circuit Malfunction (No. 4)
P1320
Igniter Circuit Malfunction (No. 5)
P1325
Igniter Circuit Malfunction (No. 6)
P1330
Igniter Circuit Malfunction (No. 7)
P1335
CKP Sensor Circuit Malfunction During Engine Running
P1340
Igniter Circuit Malfunction (No. 8)
P1345
VVT Sensor Circuit Malfunction (Bank 1)
P1346
VVT Sensor Rang/Performance Problem (Bank 1)
P1349
VVT System Malfunction (Bank 1)
P1350
VVT Sensor Circuit Malfunction (Bank 2)
P1351
VVT Sensor Range/Performance Problem (Bank 2)
P1354
VVT System Malfunction (Bank 2)
P1400
Sub-TP Sensor Malfunction
P1401
Sub-TP Sensor Range/Performance
P1410
EGR Valve Position Sensor Circuit Malfunction
P1411
EGR Valve Position Sensor Circuit Range/Performance Malfunction
P1500
Starter Signal Circuit Malfunction
P1520
Stop Lamp Switch Malfunction
P1565
Cruise Control Main Switch Circuit Malfunction
P1566
P1600
ECM BATT Malfunction
P1605
Knock Control CPU Malfunction
P1633
ECM Malfunction (ETCS Circuit)
P1645
Body ECU Malfunction
P1656
OCV Circuit Malfunction (Bank 1)
P1663
OCV Circuit Malfunction (Bank 2)
P1780
PNP Switch Malfunction
B2785
Ignition Switch On Malfunction (Immobilizer System)
B2786
Ignition Switch Off Malfunction (Immobilizer System)
B2785
B2791
Key Unlock Warning Switch Malfunction (Immobilizer System)
B2795
Unmatch Key Code (Immobilizer System)
B2796
No Communication In Immobilizer System
B2797
Communication Malfunction No. 1 (Immobilizer System)
B2798
Communication Malfunction No. 2 (Immobilizer System)
I'll rephrase - can anyone tell me 'in English' what the phrase 'Air/Fuel Ratio Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)" means? I don't need the list of codes etc - just what work needs to be done, any ideas on cost and whether or not this should be regarded as critical...
P0100
MAF Malfunction
P0101
P0110
P0115
P0116
P0120
P0121
P0125
P0130
P0133
P0135
P0136
P0141
P0150
P0153
P0155
P0156
P0161
P0170
P0171
P0172
P0174
P0175
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0325
P0330
P0335
P0340
P0385
P0401
P0402
EGR Excessive Flow
P0403
P0420
P0430
P0440
P0441
P0446
P0450
P0451
P0500
VSS Malfunction
P0505
P0510
P0550
P1100
P1120
P1121
P1125
P1126
P1127
P1128
P1129
P1130
P1133
P1135
P1150
P1153
P1155
P1200
P1300
P1305
P1310
P1315
P1320
P1325
P1330
P1335
P1340
P1345
P1346
P1349
P1350
P1351
P1354
P1400
P1401
P1410
P1411
P1500
P1520
P1565
P1566
P1600
P1605
P1633
P1645
P1656
P1663
P1780
B2785
B2786
B2785
B2791
B2795
B2796
B2797
B2798
P0100
MAF Malfunction
P0101
P0110
P0115
P0116
P0120
P0121
P0125
P0130
P0133
P0135
P0136
P0141
P0150
P0153
P0155
P0156
P0161
P0170
P0171
P0172
P0174
P0175
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0325
P0330
P0335
P0340
P0385
P0401
P0402
EGR Excessive Flow
P0403
P0420
P0430
P0440
P0441
P0446
P0450
P0451
P0500
VSS Malfunction
P0505
P0510
P0550
P1100
P1120
P1121
P1125
P1126
P1127
P1128
P1129
P1130
P1133
P1135
P1150
P1153
P1155
P1200
P1300
P1305
P1310
P1315
P1320
P1325
P1330
P1335
P1340
P1345
P1346
P1349
P1350
P1351
P1354
P1400
P1401
P1410
P1411
P1500
P1520
P1565
P1566
P1600
P1605
P1633
P1645
P1656
P1663
P1780
B2785
B2786
B2785
B2791
B2795
B2796
B2797
B2798
I beleive it to be your o2 sensors need replacing. Try searching o2 sensors? :cheers:
Your Air/Fuel Ratio sensor is failing. It is also called the Bank One sensor. The sensor itself is about $200 from a parts distributor and somewhat more than that at a Lexus parts department. Labor to remove the old sensor and replace it with the new one will also run you several hundred dollars.
If you're mechanically inclined, you can tackle this repair yourself. But you must first determine the exact location of the failed sensor. And be careful not to strip the threads in the manifold when you remove the old sensor.
To RX in NC
Thanks for the feedback - sounds like you've experienced this before. My local Lexus dealer just quoted $375 + tax for parts and labor. Does this seem fair? What rates have you been quoted for this?
When our Air/Fuel Ratio sensor failed last August, I forced Lexus to replace it under their goodwill warranty policy. If I had to pay for it, the cost would have been about the same as what you were quoted.
My wife's 2000 RX300 has suffered from many failed components during 2003 and 2004, far more than this vehicle should have experienced. As a result, I've battled with Lexus on multiple occasions and have basically had more than $9,000 worth of service performed on this vehicle at no charge to us. I research the problems thoroughly, prepare my case, and then dig in and do battle with Lexus until I get what we need. So far I'm batting 1.000 with repairs including replacing the transmission, the exhaust manifold, the front strut mount rubber bushings, the Mass Air Flow sensor, the Air/Fuel Ratio Sensor, the rear main oil seal, and a couple of other items.
Very few owners possess the stomach and relentless willpower to battle service departments like I do. But it works for us and I don't mind creating a ruckus in the dealership if I need to. The key is to remain professional and knowledgeable, but absolutely ruthless as well.
But we'll never have another RX in our household after this one runs its course. My wife will return to her beloved Grand Cherokee line-up. We've had three of them and it's a bulletproof vehicle that has been far more reliable for us than this fragile, underpowered, under-engineered RX300 crackerbox. I look forward to pushing it off a cliff when we're done with it....
Good luck with your Air/Fuel Ratio sensor.
  • Like 1
To RX in NC
Thanks for the feedback - I obviously don't check this site very often. Mine was bought used - no such manufacturer's warranty. I did purchase some extended warranty through the 'non-lexus' dealership I bought the vehicle from so I think I'll look into that although I have a feeling this will be classified as wear & tear just so they don't cover the costs... Thanks anyway.
To RX in NC
Hi! I read about this sensor in another forum(I can't recall which one, that's what google is there for), the owner did a little research and found out that the problem sensor is basically a part of the emission system of some sort, which carries a longer warranty than the basic bumper to bumper. The service manager at the dealership fixed the thing for free. There's no harm in trying...RX in NC is absolutely right!
" we only regret the things we dindn't do"
  • 4 years later...
Hi There,
I just went through the same thing.
I actually bought the replacement part (234-9009 Denso Air/Fuel Ratio Sensor) online at amazone for $139.00
For the non techie's just buy the part online and then let a mechanic put it in (1 hour) so you should be done for about $ 200.00
Hope this helps
You have to replace your Air Fuel Ratio Sensor, if you open the hood of your Lexus, it's the one towards the back. You can access is from underneath the car. It's Pretty much plug and play. Put some liquid wrench or wd40 on the sensor while it's hot. It will work it's way in as it contracts. Wait about an hour until it cools down. Then go underneath the car and unplug the sensor. Then your gonna need an Oxygen sensor socket (about $10 from your local auto parts store), also a breaker bar (about $20 from the parts store. The breaker bar just give you more torc so that the sensor come out easier. Once you have it out, screw in the new one as tight as you can with your hand, then give it 1/4 turn clockwise with your oxygen sensor socket attached to your rachet. Just snug. You don't won't to over torc it. Other wise you won't be able to get it out the next time it needs changing. Hope this helps.
I had the same failure code and replaced it myself. Good luck and take your time doing it. If the A/F sensor cooperates it should take you about 1/2 to complete the job
  • 5 years later...
What is difference between Sensor at Bank 1 and at Bank2? Are'nt they same part at different locations?
Bank 1 at rear just under firewall and Bank 2 at front behind center of radiator on exhaust pipe. Do they have to be Denso part or any generic part will work? I removed one from Bank 1 which has marking
"Toyota 89467
~ 48011
Denso 0200"
I replaced it with a generic one from eBay
item #221826329058, ending on Aug-13-15 01:50:30 PDT - Air Fuel Ratio Oxygen Sensor For Toyota Camry RAV4 Lexus RX300 ES300 8946748011
but have not been able to clear error codes which come back after driving about 15 miles and the check engine light keeps flashing.
  • 9 months later...
I took my car to Autozone store to read the errors for check engine light. They read it and told me that my coil on cylinder 1 is bad and need to replace. I bought it from Autozone for $70 with life time warranty if this one goes bad and had them reset the check engine. I have driven the car 50 miles the check engine light has gone but engine still runs rough and grabes/ha sitters to shift to overdrive/ higher gear while driving. Can some one tell me how to fix this condition?
IIs this related due to deity and clogged screen on OCV on Bank 1 or Bank 2?  I need guidance and help of  a pro tech who may post a link to fix this problem with steps by step instructions to make this repair.
