Does anyone have a list of all TSBs that apply by year to the GX470? My outside temperature unit has been replaced twice and it still does not function correctly. It starts at over 100 degrees and after about 10 minutes of driving drops to about the ambient temperature as stated on the radio.
If your vehicle has been running and you stop for a bit, the temperature might be much higher resulting from engine heat. Once you drive off, it will slowly drop to the actual temperature. It is the same as when you park it in the garage, the ambient temperature around the vehicle goes up quite a bit.
EG004-04 APR 04 Exhaust System - Excessive Sulfur Dioxide Odors
DL001-04 APR 04 Driveline - Rear Driveshaft Clunk/Thump Noise
EL001-04 MAR 04 Electrical - 'Crank Hold Syst*** Jump Starting
ST004-04 FEB 04 Steering/Driveline - Vibration/Drone
AC001-04 JAN 04 A/C - Poor Cooling in High Temperatures
EG003-03 DEC 03 Emissions - MIL ON/DTC's P0441, P0442/P0446 Set
SS002-03 DEC 03 Engine Controls - O2 Sensor Monitor Threshold Values
BO012-03 DEC 03 Interior - Seat Belt Extender Applications/Availability
EL015-03 NOV 03 Instruments - Inaccurate Outside Temperature Display
BO008-03 OCT 03 Interior - Console Box Door Won't Stay Closed
SS003R-01 SEP 03 Engine Controls - ECU Programming Error Displayed
SS001R-01 SEP 03 Engine Controls - ECU Programming Procedure
BO005-03 SEP 03 Body - Hood is Difficult to Open
BO006-03 SEP 03 Interior - Rear Door Power Window Switch Loose
BO007-03 SEP 03 Interior - Trim Panel Removel/Installation Precautions
EL011-03 SEP 03 Body - Power Window 'AUTO-UP' Feature Malfunctions
SU001-03 AUG 03 Suspension - Squeak From Front on Sharp Bumps
EL010-03 AUG 03 Lexus Link System® - Error Detected
NV007-03 AUG 03 Body - Rear Door Grinding Noise
AU002-03 JUN 03 Audio System - Rear Audio/CD Changer Troubleshooting
BO004-03 JUN 03 Interior - Front Seats 'Loose' Feeling
EL006-03 JUN 03 Navigation System - Map Screen is Blank
AX004-03 MAY 03 Cell Phone - Headphones Turn OFF in Cold Weather
PG003-03 MAY 03 Body - License Plate Mounting Precautions
TC002-03 MAY 03 Engine Controls - ECM Reset Memory Function
NV003-03 APR 03 Interior - Seat Track Squeak/Creak Noise
NV002-03 APR 03 Engine - Engine Cover Buzzing Noise
EL002-03 MAR 03 Instruments - Service Maintenance Lamp Resetting
NV001-03 MAR 03 Interior - Front/3rd Row Seats Squeaks/Rattles
TC001-03 FEB 03 A/T - A750 Solenoid Identification
EG001-03 FEB 03 Exhaust System - Sulfur Smell
SS005R-01 JAN 03 Diagnostic Tester - Immobilizer Function
PG016-02 OCT 02 Body - Moonroof Initialization Procedure
BO005-02 SEP 02 Interior - Seat Belt Extender Availability/Applications
