biggmakk Posted May 3, 2005 Posted May 3, 2005 Anyone know of an aftermarket amp that would work in a 1994 es300? My amp died. It's a Pioneer serial number 86280-33041. I think these were factory installed in the 93 to 97 ES300 models
dcfish Posted May 3, 2005 Posted May 3, 2005 Anyone know of an aftermarket amp that would work in a 1994 es300?My amp died. It's a Pioneer serial number 86280-33041. I think these were factory installed in the 93 to 97 ES300 models ← I can get you a OEM amp if you want a factory replacement.
TexasComputerMan Posted May 21, 2005 Posted May 21, 2005 Did you ever get an answer to your question? I am interested because I have a 1992 SC400 with a Nakamichi system. My cd changer died, so I installed a 6 cd changer from a pre 1996 ES300. It is plug compatible with my SC400 amp. Does that mean that the ES300 amp will also work in the SC400????
dcfish Posted May 22, 2005 Posted May 22, 2005 Did you ever get an answer to your question? I am interested because I have a 1992 SC400 with a Nakamichi system. My cd changer died, so I installed a 6 cd changer from a pre 1996 ES300. It is plug compatible with my SC400 amp. Does that mean that the ES300 amp will also work in the SC400???? ← You need the nak amp with nak headunit . B)
