Question for everyone...just want to be absolutely sure about my tie size
drop is 1.2/1.4
rims are hp evo dark 19 8.5/9.5
I want to buy 245/40 and 275/35
Will this work?  without any shaving or rolling of fenders
Rubbing will depend on the rim offset. Running this larger tire size will "work" as most of the guys running 20s have the same diameter (about 1" larger than spec). You will get some intermitent rubbing from the front when you fully lock the wheels on turns and on reverse. The ride quality is better since you have larger sidewalls.
If you want somewhat worse ride quality but no intermittent rubbing, then stay with the OEM spec and run 245/35 front and 275/30 rear. Like I said earlier, though, fender rubbing will depend on the offsets.
