Trac Light
about to buy a sensor tester but not quite sure if i need....----trac----(light) comes on after driving a mile or so and stays on until car is shut off.(thats the only light that comes on) i can not get any readout codes. sometime car will go a little farther before light again but usually a mile consistently. i think a rear wheel speed sensor is the culprit but not real sure. any sensors on throttle body or engine that might affect this? '94 gs300 135k
I believe the brake pedal may be your culprit, look for a sticky or broken switch. There are 2 or three switches on it.
I see only one switch (brake light switch) seems to be functioning ok..today drove car in wet conditions,trac light lit , wheel started spin, trac control started working with trac light flickering then light was out the rest of the drive. however, back on the next trip....???
Here's how to check the codes. The "special tool" mentioned is simply a piece of wire to short the appropriate terminals. Hint: Don't short the wrong ones! :whistles:
Trac_System_Code_Retrival.pdf
DLC2_Pin_Locations.pdf
Code_Descriptions.pdf
Clearing_Codes.pdf
no trouble codes are currently existing in system.(check has been done)
Loading...
 Share
