projzxr Posted March 13, 2005 Share Posted March 13, 2005 on a es250 with 170xxx miles on it. I was thinkin' mobil 1. What does it say in the manual? Oil filters where can I get? Thanks. Link to comment Share on other sites More sharing options...
exdotcomer Posted March 13, 2005 Share Posted March 13, 2005 on a es250 with 170xxx miles on it. I was thinkin' mobil 1. What does it say in the manual? Oil filters where can I get? Thanks. ← I thought you shouldn't change to synthetic oil on a car past 40 k miles? something about the the oil being so thin - it would wreck havec on the seals. Link to comment Share on other sites More sharing options...
cruznroadking Posted March 13, 2005 Share Posted March 13, 2005 On a high mileage car I'd recommend start with 10/30 oil & then monitor oil consumption for thre first oil change & decide whether you need to go to a heavier oil. Link to comment Share on other sites More sharing options...
ArmyofOne Posted March 13, 2005 Share Posted March 13, 2005 On a high mileage car I'd recommend start with 10/30 oil & then monitor oil consumption for thre first oil change & decide whether you need to go to a heavier oil. ← i have switched to synth on cars with 200K and i have done it to cars with 2K either way if the engine is in good working order you will be fine. do a compression test..if you are around 170-180 on all cylinders you are probably good for the switch. do a search and decide for youself. if you want my opinion, you can reach me via PM or email. Link to comment Share on other sites More sharing options...
Air Force Rascal Posted March 14, 2005 Share Posted March 14, 2005 On a high mileage car I'd recommend start with 10/30 oil & then monitor oil consumption for thre first oil change & decide whether you need to go to a heavier oil. ← i have switched to synth on cars with 200K and i have done it to cars with 2K either way if the engine is in good working order you will be fine. do a compression test..if you are around 170-180 on all cylinders you are probably good for the switch. do a search and decide for youself. if you want my opinion, you can reach me via PM or email. ← Oh NO!!! here we go again...LOL!!!!! Link to comment Share on other sites More sharing options...
ArmyofOne Posted March 14, 2005 Share Posted March 14, 2005 On a high mileage car I'd recommend start with 10/30 oil & then monitor oil consumption for thre first oil change & decide whether you need to go to a heavier oil. ← i have switched to synth on cars with 200K and i have done it to cars with 2K either way if the engine is in good working order you will be fine. do a compression test..if you are around 170-180 on all cylinders you are probably good for the switch. do a search and decide for youself. if you want my opinion, you can reach me via PM or email. ← Oh NO!!! here we go again...LOL!!!!! ← going where? thats as far a i get involved in these topics. :D Link to comment Share on other sites More sharing options...
