Solara 17's On Es300
  • 2 months later...
Anyone have these on their lexus? 17X7, 5 LUG,4 1/2" BOLT PATTERN,50MM OFFSET.
what do you guys think? They should fit ok, no?
I put IS300 17" on my 97 ES300 and they fit perfectly - if that helps!
Gen2 Camry / ES 250
Bolt pattern: 5 x 100
Offset: +38mm
Gen 3 - 4 Camry (92-01 ES)
5 x 114.3
Offset: +38mm
Gen5 Camry / 02 + ES
Bolt pattern: 5 x 114.3
Offset: +50mm
All the wheels can swap on the Camry platform. Provided they're the same bolt pattern. (Or you add a spacer for the newest ones going backwards)
