kconno Posted March 10, 2005 Share Posted March 10, 2005 92 es 300 automatic transmission has started to get jumpy/revs up and down when put into drive gear and I start to drive away and then settles down once im doing 5-10mph+. Does any one know if this is the end of my transmission/automatic gear box ? Or could it be a maintenance/service issue? Quote Link to comment Share on other sites More sharing options...
amf1932 Posted March 10, 2005 Share Posted March 10, 2005 92 es 300 automatic transmission has started to get jumpy/revs up and down when put into drive gear and I start to drive away and then settles down once im doing 5-10mph+. Does any one know if this is the end of my transmission/automatic gear box ? Or could it be a maintenance/service issue? ← Did you check your ATF fluid to see if it's up to the full mark? Quote Link to comment Share on other sites More sharing options...
kconno Posted March 10, 2005 Author Share Posted March 10, 2005 92 es 300 automatic transmission has started to get jumpy/revs up and down when put into drive gear and I start to drive away and then settles down once im doing 5-10mph+. Does any one know if this is the end of my transmission/automatic gear box ? Or could it be a maintenance/service issue? ← Yes it was well up the stick to the hot mark after 20mins driving time and the colour of the fluid was light almost transparent grey! Ive had the car serviced yearly but dont think the fluid was every changed since i got the car 3 years ago, had many mechanical parts changed (rear struts /discs ball joint etc) but the engine and transmission have been fine up to the last 2000-3000 miles Quote Link to comment Share on other sites More sharing options...
justin97 Posted March 11, 2005 Share Posted March 11, 2005 92 es 300 automatic transmission has started to get jumpy/revs up and down when put into drive gear and I start to drive away and then settles down once im doing 5-10mph+. Does any one know if this is the end of my transmission/automatic gear box ? Or could it be a maintenance/service issue? ← Yes it was well up the stick to the hot mark after 20mins driving time and the colour of the fluid was light almost transparent grey! Ive had the car serviced yearly but dont think the fluid was every changed since i got the car 3 years ago, had many mechanical parts changed (rear struts /discs ball joint etc) but the engine and transmission have been fine up to the last 2000-3000 miles ← poss. vaccum leak? Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted March 11, 2005 Share Posted March 11, 2005 92 es 300 automatic transmission has started to get jumpy/revs up and down when put into drive gear and I start to drive away and then settles down once im doing 5-10mph+. Does any one know if this is the end of my transmission/automatic gear box ? Or could it be a maintenance/service issue? ← Yes it was well up the stick to the hot mark after 20mins driving time and the colour of the fluid was light almost transparent grey! Ive had the car serviced yearly but dont think the fluid was every changed since i got the car 3 years ago, had many mechanical parts changed (rear struts /discs ball joint etc) but the engine and transmission have been fine up to the last 2000-3000 miles ← I'd service the transmission soon then. Consider doing a 100% fluid change & at the same time, you might want to consier replacing the tranny pan gasket & cleaning the filter mesh screen at the same time. B) Quote Link to comment Share on other sites More sharing options...
