andrecat112 Posted March 9, 2005 Share Posted March 9, 2005 my car has reached 70,000 miles and ive never had the valve clearence checked nor adjusted? should i have this done? Quote Link to comment Share on other sites More sharing options...
mxl4729 Posted March 9, 2005 Share Posted March 9, 2005 my car has reached 70,000 miles and ive never had the valve clearence checked nor adjusted? should i have this done? ← do u hear a taping that increaces with rpm? because that is the noize that tells u you need a valve adjusment. Quote Link to comment Share on other sites More sharing options...
andrecat112 Posted March 9, 2005 Author Share Posted March 9, 2005 during initial start up i hear it as the car is idling, but im not sure if its continuous with acceleration. any idea on the price of getting it checked and adjusted? (im taking it to a toyota dealership tomorrow) Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted March 9, 2005 Share Posted March 9, 2005 during initial start up i hear it as the car is idling, but im not sure if its continuous with acceleration.any idea on the price of getting it checked and adjusted? (im taking it to a toyota dealership tomorrow) ← i have a different engine, but i have almost 145K and its never been done according to what little service records there are, mine are working fine :) Quote Link to comment Share on other sites More sharing options...
VGR Posted March 10, 2005 Share Posted March 10, 2005 my car has reached 70,000 miles and ive never had the valve clearence checked nor adjusted? should i have this done? ← Your owners manual says the valve clearance should be checked at 60,000 miles. You can skip this service if: - you don't care about maintaining optimum engine power, smoothness, quietness and fuel economy - you don't care about achieving maximum engine life. Quote Link to comment Share on other sites More sharing options...
andrecat112 Posted March 10, 2005 Author Share Posted March 10, 2005 my car has reached 70,000 miles and ive never had the valve clearence checked nor adjusted? should i have this done? ← Your owners manual says the valve clearance should be checked at 60,000 miles. You can skip this service if: - you don't care about maintaining optimum engine power, smoothness, quietness and fuel economy - you don't care about achieving maximum engine life. ← motion carried to have it done....im definently having it done Quote Link to comment Share on other sites More sharing options...
vcv10guy Posted March 10, 2005 Share Posted March 10, 2005 my car has reached 70,000 miles and ive never had the valve clearence checked nor adjusted? should i have this done? ← Your owners manual says the valve clearance should be checked at 60,000 miles. You can skip this service if: - you don't care about maintaining optimum engine power, smoothness, quietness and fuel economy - you don't care about achieving maximum engine life. ← motion carried to have it done....im definently having it done ← Before you go and just have it done. Have your tech do an audible check on the valves. Valve adjustment is a pricey procedure, so I would have it checked first and then go from there. Quote Link to comment Share on other sites More sharing options...
VGR Posted March 10, 2005 Share Posted March 10, 2005 .im definently having it done ← Your next challenge is to find a tech with meticulous work habits - one who cares about accuracy and doesn't have a "this is good enough" attitude about valve adjusting. An audible check is not very accurate because it cannot detect overly tight valves (because tight valves are quiet) and by the time a valve cleanance is loose enough to make a ticking noise then it is severely loose. Yes checking valve clearances manually is a bit expensive labor wise and one way to save money is to have the clearances checked when the timing belt is changed because the labor needed to perform both tasks is, in part, dupicated. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted March 10, 2005 Share Posted March 10, 2005 What kind of costs can one expect when having this service done? I've never had to have any adjustments to any engine on a car I have owned other than routine maintenance. Quote Link to comment Share on other sites More sharing options...
andrecat112 Posted March 10, 2005 Author Share Posted March 10, 2005 STOP THE PRESS.....HOLD THE MAYO i didnt get the valve clearence check, because the technicians said it would cost me $350 not including labor or parts (new gaskets) and take about 5 hours. being that i dont have that much to throw down, ill have to wait on that. Quote Link to comment Share on other sites More sharing options...
vcv10guy Posted March 10, 2005 Share Posted March 10, 2005 STOP THE PRESS.....HOLD THE MAYOi didnt get the valve clearence check, because the technicians said it would cost me $350 not including labor or parts (new gaskets) and take about 5 hours. being that i dont have that much to throw down, ill have to wait on that. ← Yup, knew it was going to be expensive. I could only imagine it would be even more expensive if you took it to Lexus. Quote Link to comment Share on other sites More sharing options...
JPI Posted March 11, 2005 Share Posted March 11, 2005 .im definently having it done ← Yes checking valve clearances manually is a bit expensive labor wise and one way to save money is to have the clearances checked when the timing belt is changed because the labor needed to perform both tasks is, in part, dupicated. ← This is not true. Checking valve clearance doesn't require removing the timingbelt. Valve clearance job will cost around $350-$500. It does take time. JP Importz Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted March 11, 2005 Share Posted March 11, 2005 A job like this need to be done after only 70,000 miles? I haven't seen this type of repair (service) called for that often, if at all. Quote Link to comment Share on other sites More sharing options...
