Es 330 Starting Problem?
timothy
hello
My 04 es 330 did not want to start this morning. 12000 miles, 3/4 tank of gas, garage kept. Turned key over, started then stopped. Turned key again, would not fire, turned over fine, let it sit for less then a minute, started up, smelled gas no leaks under hood. After letting the car warm up for a few minutes, drove the car hard, almost full throttle, seems fine. Then daytime running light indicator goes off. All lights work, just the indicator not working. Could that be related? Thought maybe I hit the gas pedal when I got in the car, not sure. Seems fine now, been cold, about 5 degrees F. outside. 35 one day 5 the next. Have a good dealer, I'll call Mon. Any Ideas what's going on?
Thanks, Timothy
no indicator on es330, my goof. been driving new Saturn Vue which has indicator light.
Reading in manual that if key ring is resting on key or another key with transponder is too close engine wont start. Hope thats all it is.
Timothy
