lextildeath Posted February 25, 2005 Share Posted February 25, 2005 Ok, in the FAQ it says that some Camry and ES parts are interchangeable-including suspension. I knew this even before. But, I came across these Tein S Tech springs on ebay which are for the 1999-2003 Solara V6. I had no doubt, assuming that they would fit my 97 ES, but I emailed the seller to verify(a business not just a random person) and he said he does not know if they will fit. Also, by the same seller, Tokico blue struts are listed as fitting the ES and the Camry and the Solara. So why would he not list the springs as fitting the ES too? I do not want to buy them and then discover they won't work. It happened to me when I bought the control module for "Toyota 6 cylinders" and it would not work on an ES 300. I am just trying to VERIFY. Thank you. :D Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 25, 2005 Share Posted February 25, 2005 The suspension on a 97-01 camry /es300 are exact same the engines are not hope this helps Quote Link to comment Share on other sites More sharing options...
lextildeath Posted February 26, 2005 Author Share Posted February 26, 2005 Helps very much. Was all I needed. You are the man. Thanks very much! Quote Link to comment Share on other sites More sharing options...
