Transmission Wont Come Out :d
Floridaken
1993 Lexus SC400 UPDATE!! :D I have the car on jack stands, I have
1:disconnected the neg battery cable
2.removed the tranny dip stick
3.disconnected the throttle cable and clamps
4.removed the exahst pipe and converters (hollowed the converters out btw)
5.removed the exhaust heat insulator
6removed the rear center floor crossmember brace.
7removed the shift control rad.
8removed the driveshaft
9removed the electrical harness from the transmission
10removed the oil cooler tube clamp and disconnected the tubes
11removed the lower engine cover
12removed the torque converter inspection plate
13renived the torque converter bolts
14supported the tranny with a jack
15removed the rear tranny mount
16removed transmission mounting bolts to the engine
question is.. this thing wont budge now and Im afraid to pry it, is there somthing i missed ? or is it just difficult to come out. I dont want to force it , without knowing. any help would be appriciated
Thanks
