Some Questions...
some of my dash and radio/ac board lights went out, and the dealer wants 450 and 253.59 for those...so i am just wondering if its possible to fix those by DIY..
also, how do i replace the cup holder thing? it doesnt seem to be able to get pulled out....
and how do i take off the engine cover if i want to replace the sparkplugs? just unscrew it with the special tool?
crazyhorse,
1. contact www.lextech.org and see about pricing to fix your current dash.
2. do a search on "cup holder" as I believe another member has already posted instructions.
3. my 2002 cover has 4 allen screws in the front. I don't know what the 96 has. A torque head #30 if I remember correctly worked. An allen wrench should work also. Then is just unclips with a tug. IFixEm post excellent instructions for replacing the plugs on an ES about a week ago. Search on spark plugs and exact name of member (using his screen name) and you should be able to find it.
steviej
thanks
now i am gonna try to do it myself sometime on the weekend...
by the way, is it ok to get the timing belt change at toyota?? its alot cheaper....($275 comparing to 400 something at lexus)
and i am in WI right now....
wow timing belt change at a Lexus dealership for $400 is dirt cheap. a toyota dealership will do the job well also.
