Cleaner For Air Filter Hose
PK_Lex
I watched a tail end of the show where the guy was spraying some cleaner in the hose that attaches to air filter. I'm not sure what that was, but I think he said it was carborator cleaner. Is that safe to spray and does it help in cleaning up clogs if there are any inside the hose?
i don't really see how the rubber intake house can get clogged, but anywho
if you are going to clean that you need to clean your throttle body......that will yield the biggest noticeable gains. better throttle response, better idle ect.......
just go pick up some STP throttle body cleaner at you local autoshop....it runs about 2 dollars per can......STP i beleive is one the best in that category
