redfish0 Posted February 17, 2005 Share Posted February 17, 2005 I have a 99 gs300 with 108k on it. I have never had a problem with it whatsoever until this minor issue recently. About every 3rd time I try to start the car, I turn the ignition and nothing happens. The dash panel lights are illuminated but the starter does not engage. At that point I return the key back to the original position and turn again. Sometimes it starts on the second attempt but often it takes up to four tries. The battery is fine and I assume it is some kind of electrical issue. Any thoughts? I thank you all in advance for your help. Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted February 17, 2005 Share Posted February 17, 2005 SEARCH!!! Bad starter solenoid! <_< Quote Link to comment Share on other sites More sharing options...
redfish0 Posted February 17, 2005 Author Share Posted February 17, 2005 Great! Do you know of somplace i can get one to fix it? I can't seem to find it anywhere on the web. Is there an on line tutorial on how to change it? Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted February 17, 2005 Share Posted February 17, 2005 Great! Do you know of somplace i can get one to fix it? I can't seem to find it anywhere on the web. Is there an on line tutorial on how to change it? ← Genuine Lexus starter starter Aotozone starter starter You may also just be able to buy the solenoid or a repair kit, alot cheaper, however depending on your knowledge and skills, you may just want to buy a new or rebuilt starter. Guy may be able to post the FSM procedure. I posted on how to change it for the first gen GS, it should be pretty close. Search for that info. <_< Quote Link to comment Share on other sites More sharing options...
