1994 Es300 Timing Belt Change Help
bateman
I need help with making sure my timing belt is installed correctly. Does anyone have a repair manual with info on how to line up the marks on the timing belt with the marks on the cam pulleys so that the timing belt is installed correctly?
If you can post a like or pictures that would be greatly appreciated. I am stuck at this point and dont want to geuss, i need some help to insure that im !Removed! it up. Thanks
Bateman
