ejs Posted February 4, 2005 Share Posted February 4, 2005 You get codes on my 1993 by pressing recirc and auto buttons and turning on key. There is also info on jumping TE1 and E1 of the datal link connector and counting flashes on the check engine light. Do both of these give the same data, if so why wouldn't you just always use the reciir/auto readout? Quote Link to comment Share on other sites More sharing options...
ejs Posted February 5, 2005 Author Share Posted February 5, 2005 Figured it out, AC codes You get codes on my 1993 by pressing recirc and auto buttons and turning on key. Under hood jump the T E1 and E1 of the diagnosis and counting flashes on the check engine light for engine codes. got code 25 and 26 as my problem Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 6, 2005 Share Posted February 6, 2005 glad you did i was about to tell you that you were diagniosing your hvac system Quote Link to comment Share on other sites More sharing options...
stockgixer Posted February 6, 2005 Share Posted February 6, 2005 glad you didi was about to tell you that you were diagniosing your hvac system ← Is there a code list somewhere on the site? I recently had to reset the airbag light, after removing the instrument cluster to replace the heater core. Thanks Sonny Quote Link to comment Share on other sites More sharing options...
gcarpent Posted February 6, 2005 Share Posted February 6, 2005 Attached are the engine codes from the SC400 manual. Quote Link to comment Share on other sites More sharing options...
stockgixer Posted February 19, 2005 Share Posted February 19, 2005 Attached are the engine codes from the SC400 manual. ← How do I see the codes? Am I doing something wrong? :chairshot: Quote Link to comment Share on other sites More sharing options...
