aamir Posted January 30, 2005 Share Posted January 30, 2005 Any idea how the panel above the glove compartment is secured? It is misaligned/loose on my 1996 ES300. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted January 31, 2005 Share Posted January 31, 2005 aamir, I don't know the answer to your question through experience, but logic would indicate that it must be some sort of press fit that the air bag can explode past, without throwing any clips or such into the passenger's face. I would expect that you should be able to pry it out. My 2 cents worth....hopefully accurate, but maybe not. BUT...BE CAREFULL!!!... disconnect the battery and wait at least 30 minutes for the air bag circuits to lose any lingering electrical charge, before you attempt removing the the cover. You'll be so close to the bag that if it goes off accidentally...it could kill you. If you have any doubts about it...leave it to a professional. Good luck! Quote Link to comment Share on other sites More sharing options...
aamir Posted January 31, 2005 Author Share Posted January 31, 2005 Thanks for your input........I don't necessary want to remove it. But I am afraid that if there is any incidental bumping it might go off. Quote Link to comment Share on other sites More sharing options...
