Hello
Someone told me you can adjust the airsuspension by hand by just changing some nuts and bolts like this http://planetsoarer.com/lower/Lower.html. True? False?
Then today someone told me there is a computer thing where by u can lower the airsuspension somehow (By TRD maybe?) Again true? False? and if true what is it and where can this be obtained for how much?
Anyone else lowered their airsuspension cars before?
Thanks in advance
I adjusted all the height sensors on my 92 LS400 so it was lowered. I have no doubt that some bright engineer could do this electronically, much like "chipping" the engine ECU for more HP.
yea if you take a good look the hight sensors have tierods to adjust height probably for adjusting height from the factory. if you trick the car in to thinking that the car is higher than it actually is (lenghtening the tierods) the car will lower it self. and they do sell the controller, i saw one in japan but its like 500 bucks so im not sure it works for the US stuff and do you really want to spend that much when you could spend maybe 30min. to an hour getting the hight right?
