Removing Headlights
brucelee
 Share
Ok, I'll reply.
You probably don't have a response because this has been beaten though to the nth degree, and people typically just ignore posts that are redundant of an issue that has been thoroughly worked through. Do a search, you'll find plenty of threads with various walk-thru's, including links to sites with pictures. Trust me, I did it myself. You'll find others' experiences, pictorials, tutorials, all you could ever know about the notorious leaky headlight or headlight mods.
Good luck.
:geek:
Its all you need to know. Good luck, make sure to do it right the first time and dont rush it.
I was going to give the same advice: take your time. I sat there on a bucket in front of my car, gently wiggling it back and forth, trying different angles until it finally came out. I had it out three separate times, and one of the three took me about 10 minutes until I got it right. Comes out right away if you get the angle right, but you can't force it.
Forcing it will risk scratching or chipping the surrounding paint.
Loading...
 Share
