Maximaboy1 Posted December 30, 2004 Share Posted December 30, 2004 How long should I wait (rough estimate) for the wax to "dry to a haze"...and after i buff the wax off, should the surface be glossy and smooth? It seems after every time I wax, the car is rough. ( did i not let it dry to a haze?) Quote Link to comment Share on other sites More sharing options...
JDOwen2 Posted December 30, 2004 Share Posted December 30, 2004 If the surface is still rough after a wax you need to strip the wax (use a squirt of dish washing liguid in a bucket of warm water) then clay bar the painted surfaces and then wax. I use Zaino. Let dry to a haze, usually about 30 minutes and wipe off. If the surface is still rough after a clay bar treatment, you may need to use polishing compound to smooth the surface. Quote Link to comment Share on other sites More sharing options...
HRP Posted December 31, 2004 Share Posted December 31, 2004 Your surface should be smooth before you apply wax. Wash your car and then put your hand in a plastic sandwich bag; then rub your fingers across the surface. If it is rough, you need to at least use a claybar. And use the claybar before using a polishing compound; if the surface is still rough after using a claybar, you will need to use further measures. Surface preparation is the key to, and 95+% of the final results. I, too, am a Zaino user (read Zaino Zealot). Although I have not used it yet, I understand that the new Zaino Z-2 PRO is incredible. with an anticipated duration of at least 6 - 9 months. Suggest you check out www.zainostore.com You might also be interested in the detailing information and discussions on http://www.autopia-carcare.com/ Quote Link to comment Share on other sites More sharing options...
