imehdi Posted December 16, 2004 Posted December 16, 2004 I have a 2000 GS300. The main 120AMP fuse got blown becaue a friend of mine cross jumpered the battey as he was trying to intsall a new battery. The problem now is that the 120A fuse is stuck and won't come out. Is these a special procedure to take this fuse out.? The fuse is located in the long fuse box in the engine compartment and is labelled ALT . Its a cartridge type fuse and has a clear window on the top . Any help will be appreciated..
ColinBarber Posted December 16, 2004 Posted December 16, 2004 I'm sure it just pulls out (do you have a new one? That should confirm it is just a pull out type), very tight fit though and it may have welded itself to the contacts.
TurboGS300 Posted December 16, 2004 Posted December 16, 2004 I'm sure it just pulls out (do you have a new one? That should confirm it is just a pull out type), very tight fit though and it may have welded itself to the contacts. ← BE CAREFUL ON MY TOYOTA COROLLA 2001 THAT I USED TO HAVE IT HAD SCREWS HOLDING THE WIRES TO THE FUSE, IT WAS A 100 amp fuse. Go buy a new fuse so you can see if it is a blade type or has screw holes.
imehdi Posted December 16, 2004 Author Posted December 16, 2004 I'm sure it just pulls out (do you have a new one? That should confirm it is just a pull out type), very tight fit though and it may have welded itself to the contacts. ← Yes, I did buy a new one and it is the pull up type but somehow I still can not get the old one out. I even tried using a needle nose plier. I think you might be right , it might have welded itself to the contacts or with the plastic . If that is the case, any other suggestions? I really dont't want to force it out as it might demage something else.
TurboGS300 Posted December 16, 2004 Posted December 16, 2004 B) Maybe take a soldering iron and heat the contacts of the fuse till it releases.
bartkat Posted December 16, 2004 Posted December 16, 2004 Hope you have the battery disonnected while you are trying all this.
Kev1911 Posted April 10, 2022 Posted April 10, 2022 (edited) 8 and 10mm hiding below holding the fuse in, pull battery out, I just cut a wedge out of the fuse box on both sides to access, then glued pieces of plastic to close it back up, pulling the fuse box apart is a pita, this was easy. Edited April 10, 2022 by Kev1911 word
