well you can look on the net for an engine importer around your area preferably so you can go and look at the motor you are buying. 5speed 1j's came with MK3 supras, soarers, chasers, mark II, and maybe some other cars all the way up to 97 so there are lots around.
a good place to look is www.venus-auto.com they are located in cali. or try www.jdmaddiction.com they are located in fl. both have very good prices for what comes with the engines
my friend ordered an sr20 from there the motor was good but they gave him an auto harness and computer with a 5 speed trans so the wiring for me was a bit trickier. and they switched the crank angle sensor and just slapped it in so the timing was off so i had a little trouble starting it but otherwise everything was ok.
Another option is Toysport, they might have one. They're a little more expensive, but everything that I've gotten from there has been great, and they've always treated us well here.
