new big400 Posted December 12, 2004 Posted December 12, 2004 I have recently removed my trunk emblemd on my gs4.Ive gotten most of the tape off by just rubbing it off but but Im having a hard time getting some of the small spots off.You can barely see them but you can feel their is some left if you run your hand avr the spots.Im asking because I dont plan on putting these back on.Ive tried goo gone,rubbing alcohol,and wd40,none have worked.Does anyone know what will make this job easier?Maybe something Id have lying around the house.Thanks
BA_GS400 Posted December 13, 2004 Posted December 13, 2004 I'm a little surprised that GooGone did not work for ya! I had similar trouble on an older Acura Legend though. The only two other things I can tell you should work, are, "Goof Off" - it's yellow with a red label, *OR* Nail Polish Remover. That is is what I used on my Ac in the end.
tds Posted December 13, 2004 Posted December 13, 2004 I have recently removed my trunk emblemd on my gs4.Ive gotten most of the tape off by just rubbing it off but but Im having a hard time getting some of the small spots off.You can barely see them but you can feel their is some left if you run your hand avr the spots.Im asking because I dont plan on putting these back on.Ive tried goo gone,rubbing alcohol,and wd40,none have worked.Does anyone know what will make this job easier?Maybe something Id have lying around the house.Thanks ← Try oven cleaner
new big400 Posted December 13, 2004 Author Posted December 13, 2004 I was thinking nail polish remover but oven cleaner.That doesnt sound too safe.Have you done this personally?Ill try the polish rem. now and see.
92Lex Posted December 13, 2004 Posted December 13, 2004 I've used Easy-Off oven cleaner (yellow can) to remove painted on pinstripes...I even posted a tutorial on it.
new big400 Posted December 13, 2004 Author Posted December 13, 2004 Nail polish did it. Thanks for the help
