turkish Posted June 6, 2003 Posted June 6, 2003 I am going to put a K&N cone type filter replacement in my car. I've researched the typhoon, and other short ram/cold air intakes and they don't seem to be much punkin (as they say on the farm ). My question is: Do I need to unplug the ECU in order to reset it after I change my paper filter with the K&N? Thanks in advance
bartkat Posted June 7, 2003 Posted June 7, 2003 You shouldn't need to. Even if the K&N makes a little difference, the ECU will catch up in around 200 -300 miles of driving.
SKperformance Posted June 7, 2003 Posted June 7, 2003 yah you don't need to but who wants to wait just pull the ecu fuse rather than all the battery cables which may mean redoing all the radio presets
turkish Posted June 9, 2003 Author Posted June 9, 2003 Is the ECU fuse you're talking about in the fuse box, or on the ECU itself?
SKperformance Posted June 10, 2003 Posted June 10, 2003 should be in the fuse panel either in the dash or engine bay
bartkat Posted June 10, 2003 Posted June 10, 2003 I believe resetting the ECU is only going to take it back to the default. It's still going to have to be driven to learn. relearn as you drive. If you're just putting a K&N replacement filter in, it's not that big of a change.
Steve@Lextasy.com Posted June 15, 2003 Posted June 15, 2003 http://www.lextasy.com/storeb/agora.cgi?ca...n&ppinc=search2 We have the Blitz Drop in filter on sale.
