RX944 Posted November 22, 2004 Share Posted November 22, 2004 My SC4's brakes are damaged beyond being driven,and i decided to just save up over the winter for the supra TT upgrade. I had noticed condensation on the windows and was wondering if i could do anything to keep it as dry inside as possible, i already took the carpets out, should i just wipe all the condensation off when i see it or get a cover for it, or is there something i can put inside to keep mold and mildew from growing. thanks in advance Quote Link to comment Share on other sites More sharing options...
SCdriver Posted November 24, 2004 Share Posted November 24, 2004 If you keep your car stored for months at a time and don't have a climate controlled garage you can try the following: 1) Buy one or two containers of damp check which absorbs moisture and is usually used in closets. Check out www.dampcheck.com 2) To avoid odors etc. you can fill a kitty litter box with baking soda and leave it in the car on the floor or seat. 3) Get a breathable car cover that is water repellant. 4) If you store it for extended periods you might also consider a schumacher battery tender with automatic shut off. Good luck......... Quote Link to comment Share on other sites More sharing options...
