Hi, I have a 2000 GS400 and I wanted to update my tail lights to the 01+ tail lights. Would they fit directly or would I need to do some wire splicing or change the harness? THanks
should
meaing "has no clue"
the turn signals are in a different place so they will more than likely use a different wiring harness to plug into the light from the body
I'll just confirm what the previous posters said. The 01+ tail lights will bolt right up but you will need a new wiring harness (unless you want to cut/splice/solder).
Thanks for the replies. So I can just take a wiring harness out of an 01+ GS and it would fit right in place of my old wiring harness? Or would I have to splice wires to get the wiring harness in place. Thanks
If you have the new headlights and the new wiring harness, it is plug and play. :) Go for it.
