Ls 400 , 1995- Couple Questions
if it goes off suddenly without any cracking or any other sounds and there is no hissing from the speakrs it means the the right channel in your amp is having problems, looks like when it worms up your right channel cuts off, this might be due to the output transisotrs overheating due to their age, or it might be loss of contact somewhere in that area due to the thermal expansion.
Thanks man...
I thought there was an easy fix.... I will check connections and see...
Mine makes no difference on weather as it is same weather all the time.. its intermitent and i don't see it as a temp issue... if not i might put the a/c through the feet to ventilate some a/c :D:D:D
On a sidenote do you have any idea where the front courtesy switch is located on the 95s? I haven't been able to find them and my auto lights don't work properly w/o it working...
LMK
