HI! I have a 1993 Lexus SC300 and I was just wondering if it is normal for the fog lights to illuminate only when I use the signal lights (this happens only when headlights are on). I find this very strange. :blink: hmmmmmmm
But some people wire them to look like foglights.My friend did that so his cornering lights are on when is headlights are on.I think they look better that way.Wish i knew how to do it.
Sounds like that might be illegal.
Are there any instructions on how to wire them to come on with the headlights?
:cheers:
That would be great if anyone has some info how to do it safely and correctly.
Not as simple as changing the bulb as the beam pattern of the light is about 45 degrees off center. A better option would be to install aftermarket fog lamps in the vehicle or buy the fog lamps for the 96+ and install them. An upgrade of the vehicle wiring may be required for the additional current draw of fog lamps versus cornering lamps.
