ukrkoz Posted July 6 Posted July 6 2011 RX 350 Wife's car. Rock chip driver side glass caused 2 longitudinal cracks in it, and I had to replace it. Replacement went well, no issues. Several days ago she told me that Unlock from the handle touch function is not working, adding "I am not sure, maybe it didn't work before the glass was replaced, I don't remember". Kind of leaves it unsure in that respect. I do not drive the car. Here's what we have: 1. ALL connections are in place, I pulled door panel off yesterday again, to double check 2. ALL functions from the fob work fine. Lock, Unlock, no problem 3. Passenger side door handle sensor functions work fine, she now goes to the passenger door first to unlock the vehicle. 4. If I place my finger on the little divot on the driver handle, it will lock the door, so that sensor works fine. 5. Handle will NOT respond to Unlock request, when hand placed behind the handle. As in - not even a faintest noise, nothing. 6. Hence, motor in actuator works, BT fob connection/functions work, actuator works, all inside door Lock/Unlock functions work, the only function that does not work is Unlock from the handle sensor. 7. Did locks reset several times, no difference. 8. Went into settings, nothing unusual in door lock settings. 9. different fob makes no difference Any ideas? Thank you
