It is time to replace the rear trunk supports, but I need new clips.  So far, all the trunk supports I have found online do not include the clips.  Where can I get them for cheap?  I do not want to go to the dealer and pay $50 per clip.
I am not clear on what clips you're asking about, but a good place to look is a pull-a-part or other junkyard. Or you can purchase the aftermarket gas shocks and attempt to reinstall your original clips if needed.
CoPilot:
Here are a few budget-friendly sources for trunk support clips that fit your 1995 Lexus LS400:
🛒 eBay – Aftermarket or OEM-style clips
  • Sellers often part out LS400s or offer compatible hardware kits.
  • Look for listings that include “ball socket clips” or “lift support hardware”.
  • Example: This listing includes a full set of trunk struts and may come with clips—check the description or message the seller to confirm.
🧰 Lift Supports Depot
  • While their Amazon listing doesn’t show clips included, they sometimes offer hardware kits separately if you contact them directly.
  • They specialize in lift supports and may have compatible ball studs or retaining clips for your application.
🔩 General Hardware Option
  • The LS400 uses 10mm ball socket clips, which are fairly standard.
  • You can find universal 10mm ball stud clips or retaining C-clips on Amazon or at auto parts stores like AutoZone or O’Reilly for under $10.
  • Just make sure the ball stud diameter and thread pitch match your OEM setup.
